Discussion topic: Supplied IP address is not registered in UK
Message posted on 28 Oct 2024 10:46 PM
Hi, just tried to watch content from ITVX and it is not allowing me to do so as SKY has provided me with an IP address that is not registered on the RIPE database as being in the UK.
My address is within the range 46.25.224.0 to 46.25.235.255 which according to the RIPE database, as being registered to Vodophone Espania.
As I live in the UK (Isle of Wight) this is most annoying.
Cannot find a direct contact method to Sky to discuss this issue with them, does anyone know how I can make contact??
Message posted on 28 Oct 2024 11:26 PM
Re: Supplied IP address is not registered in UK
Switch off your router for half an hour or more and it should be assigned a new public IP address when you restart it.
Message posted on 29 Oct 2024 11:37 AM
Did a disconnect / reconnect on the SKY router and received a new address that was registered to SKY UK on the RIPE.NET database.
Problem resolved, but should not have been there in the first place!
Thank you.
