Discussion topic: Super fast fibre
This message was authored by: Sarajayne
Super fast fibre
I have had super fast fibre fitted  was told it had to be put in. Bed room the wiff singal is not getting around the home only in the bed room rooter is I wiff we ate getting  50 upstairs and 10 downstairs  was told I was paying  for over 100
Re: Super fast fibre
@Sarajayne
Try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
