This discussion topic has been answered Discussion topic: Suddenly cannot connect to wifi when more than a few feet from router
Message posted on 15 May 2024 04:14 PM
Current set-up has worked for several years. Current download speed is the usual 45 Mbps. Sky multi room box wired to router won't connect. Devices more than a few feet away won't connect wirelessly. Occasionaly get 'access point temporarily full' message one one device.
Message posted on 16 May 2024 11:56 AM
Thanks for your response. As is often the case with such issues; it all worked fine a few hours later.
Message posted on 16 May 2024 11:32 AM
Re: Suddenly cannot connect to wifi when more than a few feet from router
If you have Sky Q try resetting the router to factory settings then resetting all your Sky Q boxes network connection
