16 Apr 2023 09:19 PM
Hi
I have just had a new router sent through from sky, I need to split the wifi again for smart devices, it was simple last time and the steps seem simple again this time!!
the problem I'm having is everytime I click apply after changing the settings the screen changes to "you are not connected to the internet" then I have to start again and the loop continues???!!
any help please? Am I missing somthing simple?
cheers
16 Apr 2023 09:44 PM
Posted by a Superuser, not a Sky employee. Find out moreIf you are using an iThing over WiFi, particularly with the Safari browser, then typically access is problematic.
17 Apr 2023 02:57 PM
Posted by a Superuser, not a Sky employee. Find out moreIdeally you need to use an ethernet connected device
