16 Oct 2021 05:35 AM
Posted by a Superuser, not a Sky employee. Find out more@Susieq0701 you have posted this issue in multiple threads try rebooting your hub which usually works.
10 Apr 2022 04:22 PM
I've attempted to spilt 2g & 5g 5x now, everything goes well right up to the point that I click apply after unsyncronising them as soon as I do that I lose network connection
10 Apr 2022 04:54 PM
Posted by a Superuser, not a Sky employee. Find out more@BeSpOHow are you connected when you are trying to do all of this? Are you wired or wireless?
11 Apr 2022 01:18 PM
I'm on wireless. I guess I'm going to try and find a cable to plug into my laptop and try again
11 Jul 2022 03:18 PM
I need help with this as well
15 Jul 2022 03:24 PM
I had exactly the same issue. 4 weeks later and i have just managed to resolve it (with a very helpful Grant Lavelle from Hive/British Gas).
if you are using a Safari product (ie an iphone/ipad etc), it will kick you off the router before any changes are implemented.
Use an Android device
Untick the 'Sync 2.4 and 5.0' box
Rename the 2.4 network (no need to change the password)
Save changes
Reboot the router AND the Hive hub
Reconnect using the normal process
Hope this helps 👍
25 Aug 2022 07:39 PM
I don't have a laptop or an Ethernet cable, only apple products, is there any way I can do this split????
25 Aug 2022 07:53 PM
Having spent the best part of a month going from one phone call to another....unfortunately it would appear not. I used my son's Amazon Fire tablet to do the split. I had my neighbour's Samsung phone as a backup in case the Amazon Fire didn't work. Is there someone who has an android phone you could borrow for you to do the split?
26 Aug 2022 07:20 AM
Thanks for replying, I'll need to rack my brains for who has a non Apple device!
26 Aug 2022 08:12 AM
Posted by a Superuser, not a Sky employee. Find out more@greenfam using Chrome in place of Safari as the browser on an ios device normally works.
26 Aug 2022 01:31 PM
@Chrisee Chrome was doing the same thing unfortunately. Managed to get my neighbourly to rescue me with their laptop so smart plug is now connected, yay!
