28 Jan 2023 07:26 PM
The speed checks are showing that the broadband and Wi-Fi is working to normal speeds. Over the last 8 weeks the internet drops all of the time. I've reset, moved the router on the top of the cabinet away from phones etc but nothing has made a difference.
I've followed all the instructions on the help pages and I've even had an expert come round to check everything is plugged in properly. The service is shocking and not fit for purpose. My son is currently studying and it's preventing him from being able to submit assignments.
28 Jan 2023 07:28 PM
Posted by a Superuser, not a Sky employee. Find out more@SophieMayMum Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
28 Jan 2023 07:51 PM
I've checked this and run all tests at different times over the last couple of weeks and it says all
is good.
28 Jan 2023 08:26 PM
Posted by a Superuser, not a Sky employee. Find out more@SophieMayMum Could you please post your router stats following the link below.
28 Jan 2023 10:04 PM
28 Jan 2023 10:48 PM
I can't get into the maintenance heading, it's not accepting my password, I've also reset box to factory settings and tried the Admin as username and Sky as password as suggested.
29 Jan 2023 06:56 AM
Posted by a Superuser, not a Sky employee. Find out more@SophieMayMum Which speed checks are we talking about, as the Sky one checks the line speed to your property, which will always be different to what you get on your end devices. I suspect it is more Wi-Fi problems you're experiencing rather than actual broadband speed problems.
What speeds are you supposed to be getting/what speed does the Sky checker say and what are you getting on your devices?
29 Jan 2023 08:48 AM
I think you are probably right, how do I check this? It's taken 10 mins to actually get into this post as Wi-Fi keeps dropping!
What makes it worse is the fact we have practically zero coverage in this area for our mobile so can't even rely on using my data!
