Discussion topic: Slow wifi/no connection in some rooms
This message was authored by: kendal1
So we had our wifi fitted around a month ago and had problems setting it up, so an engineer came out and fixed the problem. We have a pretty good broadband that is supposed to be very good for big households with lots of rooms. However, ever since then the wifi is extremely slow and doesn't reach some rooms even though we live in a small flat. I've tried all the online steps and don't know where to go from here. Any help is appreciated.
Re: Slow wifi/no connection in some rooms
That's certainly what the advertising copywriters would like everyone to believe: the real world, and particularly WiFi, is frequently very different.
Avatar for kendal1
Any advice?
@kendal1
Do you have a black or a white Sky Hub?
Avatar for kendal1
we have a black one
@kendal1 What service do you have from sky, and where currently is that hub sitting in the home!
First, let's position your new hub
Where you put your hub can really affect your WiFi signal. For the clearest signal:
  • Keep it out in the open - not in a cabinet, on the floor or stuck behind the TV. About 30cm of space is best.
  • Keep it away from wireless devices like cordless phones.
  • Try to put it where you use the internet most. Your signal is stronger near your hub.
