Discussion topic: Slow speeds gigafast
This message was authored by: Welshlee82
Hi everyone,I after some feedback if possible.
I upgraded to gigafast in April.
The estimated speed i should be getting is between 780/930 mbps.
I have 700mbps to my router(new one from.sky).
Wifi speeds vary from 100mbps/700mbps  and cable is constant 88mbps.
Ive had numerous tests carried out and apparently there no issues as the speed is above the 600mbps guarantee.
Any info would be much appreciated.
Avatar for Welshlee82
Re: Slow speeds gigafast
Wifi is 100/450 mbps but fluctuates
@Welshlee82 Have you ever tried another cable from the Laptop to the Hub Ethernet port or ports! And you are sure that the laptop has a 1Gb/s Ethernet card, and the properties for the connection will show 1000/1000 if you look at that!
Hi,yes I have tried different cables.
The last one came from sky which runs from the ONT to the router port 4.
Yes my PC and Xbox are capable of running 1000mpbs (ethernet port speed).
What im referring to is the speed to my router is lower than what the estimated speed should be and the output is way lower via WiFi or cable.
Shouldn't the speed be closer to 1000mbps considering its full fibre,I'd understand a drop if it was copper cable or normal broadband.
Cheers
@Welshlee82 FF500 feed on sky, lowest sustained throughput when the external network was busy is 200Mb/s. If you think you are going to get 900Mb/s because you have a gigabit network, then that's not going to be possible. Linked below the Openreach blurb!
1. FTTP is a contended service, up to 32 users can be sharing the 2.5Gb backhaul, so you can never expect the full speed all the time, you may get 900mb when there are fewer people using it. I expect that you are sharing the backhaul with many users. If everyone was using it fully, you may only get 78mbs. Its called statistical multiplexing, which relies on the fact that all users are not utilising their connection fully, all of the time.
BT quote up to 900mb, so you are likely to get much less than that during peak times.
Speed tests pass very little data, so normally give a much higher speed.
2. The max OR connect to a splitter is 30 ( 32 is the splitter maximum but policy is 30 ) not every CBT port provided is likely to have a customer using it , so unless on a ‘new site’ that has no alternatives to OR FTTP the actual number on a splitter is likely to be way less , OR currently have about a 30% take up, so maybe 10 users per splitter , plus the majority don’t take 900Mb but slower profiles , and the chances of those ‘on line ‘ at any one time all and doing something intensive, rather than browsing / Netflix that may be consuming less than 30-100Mb , is slim , that’s why there is a 700Mb minimum speed guarantee on 900Mb …..the 2.4Gb will be plenty ,you would have to be incredibly unlucky to have any consistent congestion.
If you suspect PON congestion, try at a time when there won’t be much activity, late evening or early morning .
Although you have tried somethings to ‘ isolate’ the problem , the most obvious thing to do ( that you haven’t apparently tried ) is use the BT router , without doing that , you haven’t really proved anything , your third party router may great , but even great routers can be mis configured or faulty
@Welshlee82 Some other info take a read.
And for speed related issues good read.
https://www.ispreview.co.uk/index.php/2020/12/why-buying-gigabit-broadband-doesnt-always-deliver-1gb...
Thanks,ill have a read
