2
This discussion topic has been answered Discussion topic: Slow green flashing light on router
This message was authored by: Arwhite
Hi. I have no wifi despite this checker saying wifi is fine the light on my router is flashing very slow green not solid white
Re: Slow green flashing light on router
@Arwhite
Wi-Fi is basically the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
▪️I AM NOT A SKY EMPLOYEE (even undercover)▪️
@Arwhite
Avatar for Arwhite
Thanks very much for your answer. All sorted now. Appreciated
