03 Nov 2022 06:46 PM
I'm currently getting half the download speed I should be getting. I've tried the My Sky app and spoken to Sky and they say everything is fine at their end. I've attached my router stats but im only getting download speeds of 38 Mb through Wi-Fi or router. Any ideas?
03 Nov 2022 10:04 PM
Posted by a Superuser, not a Sky employee. Find out more@MarcusBrody So you are getting 38mb on Wi-Fi and wired connection or is it just Wi-Fi? What site are you using to take the speed test from?
03 Nov 2022 10:26 PM
It's wired and wireless. I'm using the speedtest app and fast.com.
03 Nov 2022 10:38 PM
Posted by a Superuser, not a Sky employee. Find out more@MarcusBrodyAre you able to post a screenshot of a wired test using fast.com?
03 Nov 2022 11:34 PM
A sort of screenshot. My Xbox Series X is connected by Ethernet. Here's a picture of the fast.com result.
08 Nov 2022 09:44 AM
Posted by a Superuser, not a Sky employee. Find out moreAre you still experiencing the problem? Often this issue occurs right after a line activation or fault fix and resolves itself after a few days
08 Nov 2022 09:49 AM
@jamesn123We're still experiencing it. The speed went back to normal on Friday but slowed down again on Saturday and hasn't changed since then. After talking to Sky (who couldn't see any issue) they're sending us a new router but I'm not optimistic that will resolve the issue.
08 Nov 2022 10:02 AM
Posted by a Superuser, not a Sky employee. Find out moreSounds like it could be a local issue
09 Nov 2022 10:37 AM
A new router sorted the issue.
10 Nov 2022 08:41 AM
I am having the exact same issue. Previously 78/79mbs. Now 38mbs according to fast.com and other checks.
The automated SKY checks say that the hub is receiving 79999.
Do we think this is a router fault?
10 Nov 2022 02:18 PM
Here are my stats in reference to my post above.
Should be getting 79mbs but am getting 38mbs according to Fast.com (and other tests)
10 Nov 2022 08:24 PM
I've been having the same problem on and off for a week.
router says 79999 just like yours and I get 38Mbps however I test it, WiFi or Ethernet.
it will be like this when I get home from work, and by the morning it's ok again, and I will get 75Mbps again. Some days are ok, others appear to get 'capped' at 38Mbps, I have turned everything off in my house, and I'm confident the problem is external.
not the answer you wanted, but your not alone here.
11 Nov 2022 08:25 AM
Thanks @Guybrush appreciate the reply and will monitor over the coming weeks to see if any change,
Very interesting to see multiple people hitting the exact same 38mbs - not 35, not 34 and not 41. 😉
11 Nov 2022 09:44 AM
Some folk on other posts have seen their normal speeds when using vpns which, I believe, suggested Sky was throttling their speed. I wasn't seeing any change through vpn.
Someone more learned than me might be able to explain what the issue is but all I know is that I'm (currently) back up to full speed after swapping out the router for a replacement. I have no idea if that will last.
11 Nov 2022 08:54 PM
The worst I feared has happened. The new router gave us 2.5 days of full speed and now we're back to 38.....
