15
This discussion topic has been answered Discussion topic: Slow broadband - taking several minutes to load
This message was authored by: Abstractions
Hi
My Sky broadband hub is running to slow because when I am online, and trying to shop or Post a message it's taking to long to load a website, also when I press a key the website doesn't work fast enough I am constantly stopping it from loading because, it's taking longer than about four minutes to load
Moderator note: subject of thread updated to better reflect the conversation
Re: Slow broadband - taking several minutes to load
@Abstractions delays such as those you are experiencing can be caused by a sluggish response from Sky's DNS system which turns web addresses into IP addresses. There is a relatively simple work round on an iPad which is to go into the Settings and then Wifi, click on  the Sky connection scroll down to the DNS setting and open that change the setting from automatic to manual and add a server at 8.8.8.8 and exit. This means the iPad will query both Sky's DNS and one of Google's public DNS servers which are very reliable.
If thst works it is worth powering down your Sky hub for an hour as thst will probably getvyou onto a different connection with Sky hopefully thst is working properly.
Re: Sky broadband hub
@Abstractions Could you please post your router stats following the link below.
Avatar for Abstractions
Level 2 icon
Hi, okay thanks I will try I send them
Level 2 icon
Hi
Is this, what you're asking for?
System Detailshelp
ManufacturerSky
ModelSR203
Firmware Version7.02.0501.R
DSL Firmware VersionA2pvfbH043p1.d26u
Modemhelp
Modem StatusConnected
Traffic Type:PTM
Line Rate - Upstream (Kbps):19999
Line Rate - Downstream (Kbps):79999
IPv6 Loopback Address[removed]
Broadband Porthelp
MAC Address[removed]
IPv4 Address[removed]
Network TypeMER
IPv4 Subnet Mask255.255.252.0
Gateway IPv4 Address[removed]
IPv4 Domain Name Server[removed]
Gateway IPv6 Address[removed]
IPv6 Domain Name Server
IPv6 Global Address[removed]
IPv6 Link Local Address[removed]
IPv6 Delegated Prefix[removed]
LAN Porthelp
DHCPv4On
IPv4 Subnet Mask255.255.255.0
IPv6 ULA[removed]
IPv6 Link Local Addressfe80::[removed]
DHCPv6On
WiFi Porthelp
Name (SSID) [removed]
Region Europe
Current Channel 6 (2.4 GHz), 36 (5 GHz)
WiFi AP Enabled
Broadcast Name Yes
Moderator note: personally identifiable information removed
Hi @Abstractions
Those are not quite the stats we are looking for. PLease scroll to the bottom of that page you were on and select 'Show statistics'
I am NOT a Sky Employee
Level 2 icon
Hi
is there an easier way to send this?
thanks
Level 2 icon
Hi
Is this picture, ok I hadn't seen the picture, box to send it to you.
This message was authored by: Markymate06
I've been having the same problem as you. I have just upgraded to Ultrafast but it hasn't made any difference, loading pages taking 20 seconds to load and many times it just times out.  And just like you I posted on here hoping for some help. Got asked to post hub statistics as you have, but then nobody answers, it's so frustrating.
All I seem to do is wait for pages to load even though it says I have great speeds.  All I get from Sky is, 'Unplug your router, leave it for 10 minutes, then plug it back in'. Done that several times with no change!
Regreting dumping Virgin, at least their broadband was good!!
Hi @Abstractions
Your router stats indicate you are running at the full line speed of 80mbps down & 20mbps up so I am not sure why you are seeing slow loading times.
I do see you are exclusively using WiFi, are you able to try an ethernet connected device & see if you still have the same slow loading issues?
Level 2 icon
Hi
I am going to try a, Ethernet cable to see if  it gets my tv to load things up faster, the other device's I have are iPads so I can't, use them on that.
Level 2 icon
Hi
I bought an Ethernet cable i thought there was only, a green light flashing on the back of my router and the tv guide hadn't loaded any faster, but the apps were loading faster and when, I went back to the tv guide I noticed that there's a green light flashing.
@Abstractions the flashing green light by an Ethernet port indicates data is using the link.
Level 2 icon
Hi
I tried to do this with the, iPad I turned the router off at the plug afterwards for an hour but I don't think it's made, any difference I had to reconnect, something for the tv afterwards I, changed everything in the settings but I don't think it's helped speed the internet up.
Level 2 icon
Hi
I think the Ethernet is working abit on the tv though, do the states, tell me anything's more about the speed and is there anything I can change on the states to improve the speed of the tv
@Chrisee
