Discussion topic: Slow broadband speed / no signal
Message posted on 16 Jul 2025 09:59 PM
I've been having problems with my broadband speed and the play station has lost all signal I've been on to the app and it says every thing is ok but we still have poor signal. I'm on the fast fibre
Message posted on 17 Jul 2025 07:47 AM
Re: Slow broadband speed / no signal
@Paulbuch log into the My Sky app and run the service checker which will show the speed to your hub and if you click through you will see the history for the last month and if tgst shows an issue the app should offer help.
However if that is all correct then the issue is lijely to be poor wifi signal level in your home. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
