Discussion topic: Slow and unstable broadband
This message was authored by: Tom.b93
Hi,
Help needed with my broadband as it's very intermittent and slow. Not been an issue in a long time and not sure what's happened/gone wrong.
Its been an ongoing issue for a few days and k thought a factory reset of the router had fixed it but issues are back this morning. Here are some stats:
Avatar for Tom.b93
Re: Slow and unstable broadband
Any help appreciated
@Tom.b93  What device are you using to do speedtests with?
Avatar for Tom.b93
Ookla. Happy to post results if there's someone who gives a better picture
@Tom.b93oklia is the website. What device are you using to measure and do speedtests with?
Avatar for Tom.b93
Sorry, misread that. Testing in my phone and laptop.
@Tom.b93  Is the laptop only connected to Wi-Fi or was it hardwired to do the speed tests or is it able to?
Avatar for Tom.b93
Hi,
I've connected the same laptop up to the router with a wired connection and here are the results:
Do you think this is a WIFI issue?
Avatar for Tom.b93
Should add that the wired connection to my Sky Q is having similar issues.
