Discussion topic: Slow Broadband Speed 500 Mbps Fibre
Message posted on 20 Oct 2024 12:09 PM
Hi i had UltraFast 500 Mbps installed on Friday. After doing a Speedtest its 160.5 download and 66.03 upload. Does it take time to settle? What sort of speeds do you get? Thanks
Message posted on 20 Oct 2024 12:30 PM
Re: Slow Broadband Speed 500 Mbps Fibre
Those would be entirely plausible speeds over WiFi. How are you carrying out the testing?
Message posted on 20 Oct 2024 01:27 PM
Full-fibre doesn't require any settle-in period, so getting those speeds mentioned over a wired ethernet connection is either contention or a fault.
Message posted on 26 Oct 2024 05:32 PM
I downloaded the Speed Test app
Message posted on 26 Oct 2024 05:56 PM
Yes, but on what device(s)?
Message posted on 26 Oct 2024 06:09 PM
Samsung S24, Sky Q, occasionally Xbox Series S
Message posted on 26 Oct 2024 06:40 PM
The Samsung S24 is compatible with the WiFi 7 standard and Sky Max is only compatible with WiFi 6 and only the 5Ghz band but I'd expect the speed to be much higher than you are measuring on the devices concerned especially if the Xbox Series S is wired.
My own Xbox Series X which basically has the same ethernet port 1Gbps gets a throughput of about 850Mbps on a 900Mbps connection, so something is wrong somewhere. Over wireless I'd expect an issue with it being only WiFi 5 802.11ac on Xbox Series S.
I'd recommend you look at wiring the Xbox Series S for best performance and upgrading the router to WiFI 6E or better that uses the 6Ghz band and 160Mhz width channel which lacks interference from other devices in the airspace because nobody is using it currently for Samsung S24.
Message posted on 26 Oct 2024 07:34 PM
Just to give you a comparison on 900/100Mbps connection with Zen on an Xbox Series X mine reports as follows in the network testing in on settings in Xbox on wired connection:-
Message posted on 06 Dec 2025 12:56 AM
I've got a question, i also got it recently (Sky Full Fibre 500) i've been getting good download speeds etc, around 200-300mbs on xbox and pc. But today my internet has been terrible out of nowhere every game i play im stuttering etc like crazy, Even the download speed has gone all the way down to 7mbps. I also cant use an ethernet as the hub is downstairs and my setup is upstairs. Is there anything i can do to sort this out or do i just need to leave it and hope it comes back?
