24 Jul 2023 01:35 PM
I have just started using Sky Wifi Max and have a Booster supplied by sky. It not a small plug ones as advertised buy the larger square one called SE210a. My question is the Wifi Max is 6 hrtz but i am unsure that the booster is a feel it may be 5 hrtz or less.
will this effect the wifi coverage?
thank you
24 Jul 2023 01:40 PM
The sky broadband booster se210 operates a different mesh system to the sky max mesh pods and are not compatible for that reason
You can claim up to 3 sky max pods are are sent out on loan
24 Jul 2023 03:11 PM
Sky will be requesting the return of the current booster along with its matching Hub. They don't currently automatically supply a WiFi 6 pod with a Max Hub even where the subscriber has claimed a booster in the past.
