Discussion topic: Sky website broadband availability
This message was authored by Markmad This message was authored by: Markmad
Hi,  Just wondered if this is quite common...put postcode and phone number on the website, said I could get superfast35. Signed up for broadband (and TV package), only to receive email next day saying broadband cancelled.  Several calls and days later Sky tell me that I actually can't get broadband where we live,  yet website said I could??
Re: Sky website broadband availability
@Markmad
Could you enter your full postal address below and post the table and notes below it after removing your address from the image
Markmad
Thanks for the reply, below of any help? (Currently with BT fibre 2)
Markmad
@Markmad
Shouldn'nt be an issue. Showing 61-63 Mbps and available slots in the cabinet. Also the fact that you already have bt fibre should mean a straight forward line transfer and remote activation.
Suggest you call sky again for clarification
@Markmad @cookiemonsteruk
Possibly not an area actually covered by the Sky network?  The same availability checker for our address shows ADSL, FTTC and FTTP, but BT is the only ISP with a network presence (which doesn't get noted on such a lookup).
Markmad
Cheers, thanks very much. I've nearly lost the plot where I've spent so long on the phone, pretty sure they were saying that Openreach were the ones saying not poss.
Again, thanks a lot for your help!
Markmad
@cookiemonsteruk
Many thanks!  Rung Sky, I can now apparently get broadband superfast,so signed up,  cheers again.
Can i ask something else (apologies for the ignorance)
1) If I get an extended length ethernet cable to connect sky Q box to sky router, are they pretty much the same, or certain makes to go for?
2) Some time ago sky engineer put a broadband booster in (close to my old BT router and not far from tv), do I still need that if I connect new sky router to Q box via ethernet cable?
Many thanks
@Markmad
@Markmad wrote:
@cookiemonsteruk
Category 5e gigabit ethernet cable should be good for 100 metres
Many thanks
Not unless you want to cover more of the property than the sky q box.  Not sure if you need to resubscibe to broadband boost and the booster may need changed unless it is a white version of the sky router.
ie horizontal sky q booster for er115 sky q router and vertical sky broadband booster for the sky broadband hub sr203
