Discussion topic: Sky stream pixalating and loosing signal
Message posted on 03 Nov 2024 07:40 AM
Message posted on 03 Nov 2024 08:21 AM
Re: Sky stream pixalating and loosing signal
@Hannah4191 run the Network test in the Get Help menu of the Netflix app on the puck and post the result. By far the most common cause of pixelation on Stream is poor WiFi as the pucks need decent speed say 35Mb/s for UHD AND a stable signal not affected by interference. You can help improve things by making sure both the hub and the puck are out in the open and on a surfaceso they are above obvious obstructions beyong thst you are into needing extra kit.
In an ideal world use an ethernet cable.
Message posted on 01 Dec 2024 01:56 PM
Done everything except hard wire via Ethernet. Put in mesh system and still awful reception. Sky why do you just bury your head and ignore this issue ?
