Discussion topic: Sky stream keeps stalling and goes to a blue screen
This message was authored by: ScottishRay82
For the past couple weeks my sky stream has been stalling and struggling to load the programmes, then goes into a blue screen. I've tested my broadband (25.1) and my stream is hard wired into my hub via Ethernet. Any ideas why this is just started happening?
Re: Sky stream keeps stalling and goes to a blue screen
@ScottishRay82
That's only fractionally above the minimum which Sky recommends for Stream: if there's any other internet usage at the address then you're likely to below the minimum.
