Discussion topic: Sky sent new hub and some devices won’t work now
Message posted on 28 May 2024 03:52 PM
Sky sent a new hub as part of a changed package. Now some devices including Blink cameras won't connect Any ideas?
Message posted on 28 May 2024 04:28 PM
Re: Sky sent new hub and some devices won’t work now
Which hub did you have before and which do you have now?
https://www.sky.com/help/articles/set-up-hub-which-sky-hub-do-you-have
Message posted on 30 May 2024 02:24 PM
The old model is ER115 and the new one is SR203.
Thanks for trying to help.
Message posted on 30 May 2024 04:49 PM
Dull question but you did reassign the blink door bell to the new Sky Network name ? ie old SKYXXXX , new SKYYYYY
The only other thought is that Blink runs on 2.4Ghz so that needs to be enabled on the router.
Message posted on 30 May 2024 04:54 PM
I did reassign to the new SKY network but I don't know anything about 2.4 xx.
Do you know how I could check it and change the router if necessary. Thx again.
Message posted on 30 May 2024 05:01 PM
In a web browser (Edge, Chrome , Safari etc ) do the following :
1. In the search bar type : 192.168.0.1
2. the username is ADMIN , the password is the password for your network
3. Select the WiFi tab
4. Try unticking synchronise 2.4GHz and 5Ghz to see if it makes any difference
All this does basically is splits the network into 2 , you could add a -5 to the end of the name of the 5Ghz for now
Message posted on 31 May 2024 03:12 PM
I typed in the code in the search bar which was fine.
I then tried to put in username ADMIN, and it wouldnt accept it. Where should I put ADMIN?
Message posted on 31 May 2024 03:20 PM
You should get something like this screen
Message posted on 01 Jun 2024 05:30 PM
I managed to update the software and it seems to work now. Thanks for trying to help
