3
This discussion topic has been answered Discussion topic: Sky router model SR203 connection problem to my toshiba smart tv
This message was authored by: RAY74
I have two toshiba smart tv's which will not connect wifi to my sky router model SR203.Have done resets on both tv's but they will still not connect.Is it the sky router that will not work with the toshiba tv's.If there is anything i could try i would welcome any advice
Avatar for RAY74
This message was authored by: RAY74 Answer
Re: Sky router model SR203 connection problem to my toshiba smart tv
Bought a 10 mtre Ethernet cable connected up and surprise worked right away.Getting good consistant speed of 90mbs.Will leave well alone probably a fault with the WiFi module on tv.Thank you for help.
@RAY74
You may need to unsynchronize and rename the WiFi bands.
As posted by @jamesn123
Note that this process does not apply to the new (white) Max Hub
So to split the two channels you need to go to your router config page which can be found by typing 192.168.0.1 into your web browser.
To access the page, you'll need;
username: admin
password: sky OR your WiFi password
- Select wireless from the navigation bar and scroll down a little and untick the 'Synchronise 2.4GHz and 5GHz settings'
- Scroll to the bottom of the page and hit apply.
- Once the page reloads you need to go to the 5GHz wireless settings page on the sub navigation bar below where you click wireless before
- In the 5GHz section you want to go to the box called 'Name (SSID)' and add something like 5g to the end of the current name
- Scroll down and hit apply
- Then on any wireless device you should now see two networks. One network will be the same name as usual and will be 2.4GHz band and the other will be the usual name with 5G on the end (Or whatever you typed). Connect any 5GHz capable device to the 5GHz network and see if it works correctly. The WiFi password should be the same if you havent changed it.
Avatar for RAY74
Thank you for replying,my laptop mbl phones all connect fine to the router but the two toshiba tv's will not.Cannot think that the two tv's are faulty.Did not want to go down the road of changing router settings incase it causes issues with my skyQ
Avatar for RAY74
