3
This discussion topic has been answered Discussion topic: Sky request to move to 1:1 map-t
This message was authored by: Hlpool1
Hi,
how do I request sky to move from ip address sharing and move to  1:1 map-t?
I've seen forms on the forum but they are no longer working.
thanks
This message was authored by: CellarDoor Answer
Re: Sky request to move to 1:1 map-t
Hi
If you're issue relates to a VPN being 'blocked' then I used the form below last week and sky made the change at their end.
I do not think you can change the setting in the router yourself.
https://www.sky.com/help/forms/vpn-configuration
@Hlpool1
Sky will only fulfill requests for it if there is a specific issue you are experiencing. Alternatively you can trigger your hub to change the mapping by enabling UPnP or setting a port forwarding rule.
I am NOT a Sky Employee
This message was authored by: mrandmrse
How can I do that, I've tried logging in as admin to the ip address but can't see the part to change this
Hi
