5
This discussion topic has been answered Discussion topic: Sky q wifi booster
This message was authored by: Doris66
Sky q wifi booster
Hoping for some help, I have a sky q btoadband hub (as pictured), I'm getting signal upstairs however my work laptop signal keeps dropping out so not a stable connection, a wireless booster has been suggested so I ordered one however I cannot get it to connect (even in the same room as my hub) and I am unsure whether I therefore need a specific booster for my hub? Or if anyone can help with this issue. I will attach pics of both the hub and the booster which didn't connect
This message was authored by: JPR007 Answer
Re: Sky q wifi booster
@Doris66 Where did you order the booster from? That one is for the later SR203 router, not the one you have, so I'm suspecting this wasn't ordered from Sky?
Each generation of router had its own matching booster to match and they're not cross compatible.
Zen Superfast (FTTC), Fritzbox 7530, Sky Q 2TB UHD v3 (x1), Sky Q Mini (x2), Alienware Area 51-M, Panasonic TX-65HZ1000B, Denon AVR-X6300H, B&W CM8 S2, B&W CM1 S2 (x2), B&W CM Centre S2, REL S3 SHO (x2), Panasonic TX-P42G30B, Monitor Audio RS6, Marantz PM7001 KI, Denon HEOS 1 HS2 (x2), B&W P7, iPad Pro 12.9" (5th Gen), iPhone 14 Pro Max, iPad Mini 6 (work)
** No - I have nothing to do with Sky **
@Doris66
The Q Hub has a matching Q Booster (same shape as the Hub but in white plastic) with a model number of EE120
Avatar for Doris66
That's what I wondered, i did have a discussion with sky re rhe booster and they recommended I order it online as they do not offer a booster for the hub I have, and I did not want to swap the hub. Do you know which booster would be compatible?
Avatar for Doris66
Thank you @TimmyBGood I think that's the one I thought I ordered so reckon they sent me the wrong one, I think it's this one
@Doris66
You've been sent a later model, which matches the Sky Broadband Hub.
Strictly speaking, boosters acquired anywhere but from Sky themselves aren't legitimate anyway, but as Q Hubs are approaching obsolescence I suspect Sky doesn't care very much.
