Discussion topic: Sky q router
This message was authored by davewon This message was authored by: davewon
Sky q router
How do you get a sky q router
Re: Sky q router
Ask Sky is your best bet @davewon
This message was authored by Daniel0210 This message was authored by: Daniel0210
Re: Sky q router
@davewon
That will depend of what broadband you currently run. The Sky Q hub is the current router for FTTC Superfast connections that are not using Sky VOIP.
▪️I AM NOT A SKY EMPLOYEE ▪️
This message was authored by Skull+Treaty This message was authored by: Skull+Treaty
Re: Sky q router
@davewon
Should you opt to join Sky Broadband, the Sky Q Hub is the valid Hub for a "Superfast" connection (unless you have 'internet' calls and/or Broadband Boost or your connection is over FTTP)
"Sometimes, the only choices you have are bad ones, but you still have to choose"
