Discussion topic: Sky q router will not connect WiFi reliably to internet
This message was authored by: Modelfier
On my iPhone and iPad I can forget the network, rejoin - and the divice will connect to the internet. However, when I try to use the device later, connection to the internet has been lost.
I have tried rebooting the router and devices, alsohave set Briadband Shield to 18. All to no effect.
I have run a status check on line with Sky. It shows Wifi is connecting to devices, and broadband is fine.
I am beginning to thing I need to contact Customer Support and see if I can arrange for an exchange router but thought I would run this one past the community first. Any thoughts?
Re: Sky q router will not connect WiFi reliably to internet
@Modelfier
Does it happen on all devices or just your iPad/iPhone?
I am NOT a Sky Employee
Avatar for Modelfier
Level 3 icon
Also my windows 11 laptop.
@Modelfier
So the devices disconnect and wont reconnect without you forgetting the network and putting the password in again?
Level 3 icon
In the case of my iPhone and iPad, yes. But even when ai do that - the next time I pick the device up, I have lost the coneection again. Not sure what to do on Windows 11 laptop.
