Discussion topic: Sky q box won't connect to hub
This message was authored by: Dave12m
Message posted on 26 Jul 2025 10:11 AM
I've turn everything off and back on sky q box will not find the hub. I've restarted them separately and together and they won't find each other . Service checker says everything's OK. Then says can't continue service checker
Find out more
Message posted on 26 Jul 2025 10:26 AM
Re: Sky q box won't connect to hub
@Dave12m you can connect a main Q box to any Sky hub but if connecting to the new white hub go into the TV box's menu and use the method of choosing the SSID and typing the pasword rather than using the wps method recommended for Sky hubs.
