Discussion topic: Sky performance poor and they don’t care
This message was authored by: Blythy
My family and I have been using sky for as many years as I can remember but enough is enough. The broadband keeps dropping out the mobile service is unstable both of which are impacting my wife and I professionally and personally.
You try and contact them and get an AI robot chatting away avoiding answering the issues
this is so disappointing
Re: Sky performance poor and they don’t care
@Blythy
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
For your mobile issue you perhaps need to start a thread on the Sky Mobile board explaining the problem.
