Discussion topic: Sky mobile uses data rather than wifi within house.
This message was authored by: biggustimmus
Within the house we have a nunber of devices attached wirelessly. My phone says it's connected but it still shows 4g.
This message was authored by: JPR007
Re: Sky mobile uses data rather than wifi within house.
@biggustimmus Assuming you have Apple devices, they commonly have "Wi-Fi assist" enabled in settings. If the device determines the wifi connection to be poor, it will drop back to using a cellular connection.
Sometimes it can be worth forcing the device to stick with WiFi.
On an Apple device it is under: Settings > Mobile Data > WiFi assist (scroll down).
Zen Superfast (FTTC), Fritzbox 7530, Sky Q 2TB UHD v3 (x1), Sky Q Mini (x2), Alienware Area 51-M, Panasonic TX-65HZ1000B, Denon AVR-X6300H, B&W CM8 S2, B&W CM1 S2 (x2), B&W CM Centre S2, REL S3 SHO (x2), Panasonic TX-P42G30B, Monitor Audio RS6, Marantz PM7001 KI, Denon HEOS 1 HS2 (x2), B&W P7, iPad Pro 12.9" (5th Gen), iPhone 14 Pro Max, iPad Mini 6 (work)
** No - I have nothing to do with Sky **
Avatar for biggustimmus
Thanks I think it may be the WiFi strength - have adjusted phone settings as you suggest. I was on a thing called WiFi boost, just replaced with WiFi max to see if that makes a difference.
