Discussion topic: Sky max pod won’t connect but sky extender box does
This message was authored by: Dorsetdude
Hi I previously had a broadband sky extender box put in with my modem by engineer as I live in a long house. I have upgraded to sky max and been s nt a hub and a pod. The hub has connected ok but the pod won't. If I move the pod close to the hub won't it limit how far it can send signal. I have now reconnected the extender bc from previous set up and all is working. However do I need to use the max pod to gain benefits of max
Re: Sky max pod won’t connect but sky extender box does
Hi @Dorsetdude
It would be recommended to use the pod as it will work best with max. The idea is to place the pod in a central position between the area that needs coverage but also in a good signal area from your hub so the booster itself can get a good connection. You may need to daisy chain more than one pod to reach all areas.
I am NOT a Sky Employee
