13
This discussion topic has been answered Discussion topic: Sky max pod not connecting to sky max hub
This message was authored by: tonycoughlan311
Hi any help appreciated please...
I haveone sky max hub and sky max hub only just arrived  in the last few days. Plugged  in hub and works fine, when i recived the sky max pod i plugged in and it found it and it connected well. A day later and the pod has disconnected, is flashing white lights and i can't get it to connect. Called sky and they said to reset router, which i did, and  bring the pod closer and it is now right next to the router, inches away and still will not connect, have left it over an hour and no connection. I  have tried using the mysky app and typing in srial number to connect and it doesnt like that either.
A few questions,
 Can i just ethernet link the the pod to the router, let it configure wifi, disconnect and then place upstairs and then let it connect again?
 Is there a way to reset the pod at all?
Any advice. support appreciated, thanks !
This message was authored by: Addie15 Answer
Re: Sky max pod not connecting to sky max hub
This message was authored by: CDH_Surrey
Did you receive any help with this. I am in the same situation.
Avatar for tonycoughlan311
Hi there,
yes I did get it fixed in the end but not due to Sky. I  used a cat 5 cable and connected it to my router directly and then checked it synce ld n the my sky app under broadband devices. It did and then I moved it upstairs and connected it to the wall and then checked the my sky app again and it kept connected. The max boosters do seem to go in and out of connection sometimes though, but I overcame this by moving the router more into the house. The engineers are pretty good and are helpful, you should book a visit Hope this helps.
That's really helpful. Thank you. I'll try that but also keep the engineer booking.
This message was authored by: JJ53
Hi
i have the same sort of problem
The Sky Max Pod arrived today and will not connect to the hub?
I have also tried to attach manually with serial number and it does not work
Connect it using an Ethernet cable directly to the hub. Then move the max booster to where you want it and wait for it to connect again, or book an engineer visit if that fails. I did  this and it worked first time. Good luck with it all
This message was authored by: Eva10
I'm having the same problem.  I've been on the phone to sky for over 2 hours and no one can help me.  I've tried using an Ethernet cable still doesn't work 😡
This message was authored by: AYates3097
Same issue, Pod arrived today as the coverage in my house isnt great so upgraded to the Max router which arrived first then the pod a few days later. Plug it in just keeps flashing? tried connecting to router via an ethernet cable and placed next to the router and still nothing? Any ideas?
@AYates3097 Have a look and see if any of the help works if not contact sky and make sure it is all matched to your account.
https://www.sky.com/help/articles/sky-wifi-booster-what-do-you-need-help-with
I connect the pod to the router via ethanet cable and I moved it to where I wanted it and it started to work! Solved
@AYates3097 So what happened between your 1st attempt and the last reported now working as you had tried it all before, or was it just on the account side?
I left the pod connected to the Ethernet for a while say 30min and it eventually connected. I then moved it and it worked straight away and connected wirelessly! I was was a little bit premature posting earlier saying it didn't work! Try the Ethernet cable if you can 👍🏼
@AYates3097 That's not a problem clearing it up as you have done now is way better especially when someone comes and see's the post. Thanks for that.👍👌
