Discussion topic: Sky max not working well on laptop
This message was authored by: Kel_22
Message posted on 03 Feb 2025 06:46 AM
My next sky max is not working correctly on my laptop. Was fine with previous superfast wifi now not getting good connection
Find out more
Message posted on 03 Feb 2025 07:09 AM
Re: Sky max not working well on laptop
@Kel_22 wifi dignal strength is affected by thhe layout and type od construction of uour home however if the new hub is in the same location as the old hub you should get similar signal,strength. However if you have Sky Q boxes things can be different as these no longer act as wifi extenders.
