Discussion topic: Sky max hub with pod a couple of issues - speed dropped and disconnections
Message posted on 14 Dec 2025 02:58 PM
Sky max hub 500 with pod a couple of issues - speed dropped and disconnections.
Live in a 1980's bungalow.
Issues - 1) hub is in bedroom moved pod to hallway and Wi-Fi speed in lounge 450mbs however issues with sky stream buffering in the lounge. Moved pod to lounge and connected via Ethernet cable no issue with streaming but speed on other devices used in the lounge are now 40-70mbs not 450!
2) iPad, iPhones and sky stream need to reconnect to Wi-Fi each morning seem to drop connection.
Any suggestions please?
Message posted on 14 Dec 2025 05:14 PM
Re: Sky max hub with pod a couple of issues - speed dropped and disconnections
@Fergieboy Move the sky Hub to the middle off the property to start with by the sounds off it!
Message posted on 14 Dec 2025 07:36 PM
Unfortunately the cable to the property is in the bedroom, I did want it to the lounge but they weren't keen on digging up the garden so unfortunately moving the hub isn't an option but thank you for replying.
