Discussion topic: Sky max hub not using 160mhz channel
Message posted on 22 Jul 2024 09:34 PM
Hi,
My Sky Max hub doesnt use the 160mhz channel (I need it for my wifi 6 compatibility with my TP link TXE70UH) nor can i change network channels.
Any ideas?
Message posted on 22 Jul 2024 09:48 PM - last edited: 22 Jul 2024 09:49 PM
Re: Sky max hub not using 160mhz channel
Message posted on 22 Jul 2024 10:09 PM
Thank you for your reply
do do you know if it's possible to use a non DFS Channel but not with 160mhz so as to not cause radar interference?
Message posted on 23 Jul 2024 06:06 AM
@JakeB_02 short answer is no. If you check the web interface at 192.168.0.1 for your white SR213 hub, which is for information only but does show some useful stuff. Log in using the username admin and the default wifi password then select Connection/WiFi 5GHz you will see the unit is set to use 20.40/80MHz bandwidth and automatic channel selection however you cannot change the option to also use 160MHz bandwidth as that option is greyed out. No Sky hub offers much customisation but the SR213 is the worst in that area. The DFS licencing in the UK is probably why.
The hub on its own does support WiFi6 (not 6E!) and most devices connect properly but the pod extenders are only WiFi5.
Message posted on 23 Jul 2024 07:17 AM
Thank you for your response!
I see, that's rather annoying. Starting to wish I just went to other BT or someone else due to the sheer amount of problems I've had with setup and installation also :,(
Thanks anyways guys!
