Discussion topic: Sky max hub nd booster not synching
Message posted on 10 Jan 2026 08:05 PM
Please could somedbody advise on the following issue?
I have recently upgraded my sky from the SkyQ hub to the Max Hub and gone PFTP as there is not a FFTP currently at my address. I have set up the max hub as described and also the supplied sky pod, however as my house is solid stone construction and pre 1900s the signal in the property is not the best.
However I have followed all of the instructions to reconnect the sky booster (on the old router) to the max hub and the WPS system on the booster, after trying the hard reset more than once, the instructions on the my sky app to change the security as settings etc, the booster does not want to play ball.
The green connected light comes ON, then defaults back to the flashing AMBER default with no joy. Please could advice be supplied if there is anything that I am doing incorrectly. Or is the old booster not compatable with the new equipment.
Many thanks in advance.
Message posted on 10 Jan 2026 08:24 PM - last edited: 10 Jan 2026 08:30 PM
Re: Sky max hub nd booster not synching
@allanh04 Your old SE210 sky Broadband booster does not work with the sky Max hub!
https://www.sky.com/help/articles/sky-wifi-booster-what-do-you-need-help-with
