Discussion topic: Sky max hub isn't showing on sky app
This message was authored by: SavageTempah
Message posted on 07 Jun 2025 12:27 PM
My sky max hub isn't showing on the sky app and I can't change my internet settings so I'm able to connect my ps5
Message posted on 07 Jun 2025 12:43 PM
Re: Sky max hub isn't showing on sky app
@SavageTempah Are you just new to sky with a new installation off the sky Max?
Message posted on 07 Jun 2025 12:45 PM
yeah I've had over 24 hours which they should it could take up to but still nothing
Message posted on 07 Jun 2025 12:49 PM
@SavageTempah Would suggest you leave it longer for it all to be attached on your account side, if you do not wish to then call sky and see what is your advice.
