Discussion topic: Sky max hub doesn’t work pod won’t connect
This message was authored by: LauraMars
Message posted on 22 Nov 2024 01:02 PM
Dear all
Our new Max router is terrible, wifi drops out constantly and barely reaches next room. The pod sent will only connect via ethernet cable and then disconnects when unplugged which obviously completely defeats the purpose. I'm so through with this!
Find out more
Message posted on 26 Nov 2024 11:28 AM
Re: Sky max hub doesn’t work pod won’t connect
How far away are you placing the pod? Ideally it should be in the middle of your router and the location you are struggling with WiFi. If you palce it too far from the hub then it wont connect as you've found.
I am NOT a Sky Employee
