Discussion topic: Sky isn’t working
Message posted on 26 Aug 2025 02:24 PM
Sky isn’t working
4amber lights on sky box
Message posted on 26 Aug 2025 02:37 PM
Re: Sky isn’t working
@Sky183
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
