Discussion topic: Sky is throttling my connection to certain sites.
Message posted on 04 May 2025 12:40 PM
Sky is throttling my connection to fast.com and I can prove it.
When using speedtest.net I get what I would expect I pay for 300Mb and get around 280, this is a wired ethernet connection.
When I speedtest through fast.com I get 30Mb.
When I turn on my VPN and speedtest again through fast.com I get compatible speeds to speedtest.net.
This is irrefutable proof that sky has the ability to and does throttle connections to certain domains and services.
How is this acceptable.
Message posted on 04 May 2025 02:43 PM
Re: Sky is throttling my connection to certain sites.
@MrBenjamin It may be just a simple routing issue and not a throttling issue(what would be the point in Sky throttling speeds to a single speed test site?).
From my experience fast has been very inconsistent recently, i don't use Sky broadband and whne using fast I get speeds that vary from 10mbps to 500mbps, even on the low days I have no issue streaming netflix(which fast is part of), simply because it's a false result as speed test.net and speed.measurementlab.net both report 450+mbps at the same time.
Message posted on 04 May 2025 03:31 PM
Have to say I'm struggling to understand why any ISP would choose to throttle speed testing site and so generate more support calls....
Message posted on 07 Jun 2025 04:50 PM
Hi, yeah, I just noticed myself. I upload to file hosters a lot and if I use my VPN, I uplaod a 1 gigabyte file at around 2.26 MB/s but if I don't have VPN on then it uploads at around 200 KB/s or eight times slower.
Needless to say, as soon as contract up, back to previous broadband provider.
