6
Discussion topic: Sky hub
This message was authored by Botchway This message was authored by: Botchway
Sky hub
Which area or section do I go to change the admin password without compromising my Wi-Fi password.Help will be much appreciated.One more question is my son is into the internet like he owns it and has added all these UNKNOWN DEVICES .I have asked him and he denies any issues.I need to monitor my internet hence me asking from the sky community.I need to get rid of these devices and where to go to find out what particular devices they are.Help and know how will be appreciated.Thanks
This message was authored by Chrisee This message was authored by: Chrisee Answer
Re: Sky hub
@Botchway if you have any Apple devices by default they hide their ids as do some other msnufacturers devices. Its nothing to worry about its to help,protect privacy..
To change the admin password log into the hub by typing 192.168.0.1 into a browser and once the landing page loads click on Maintenance/Set Password if you havecthe SR203 router notecthe password rules which require it to becat least 10 characters long have both lower and upper case letters and at least one number.
Re: Sky hub
Re: Sky hub
@Botchway
'Unknown Device' can also indicate that the MAC address (a globally unique number burnt into a network chip) was assigned to a manufacturer of chipsets rather than finished devices, so it's not possible for the router to identify the hardware involved: this is often the case with the so-called 'IoT' ('Internet of Things') from cameras to coffee machines.
Botchway
Re: Sky hub
Thanks folks,I am getting a grip with all these tech stuff.One more burning question-is it possible to change my IP ADDRESS and how do I go about it if it's possible to have it done
Botchway
Re: Sky hub
Is it possible to have my IP address changed.And if it can be done,how do I go about it
Botchway
Re: Sky hub
Is it possible to change my IP address and if I can ,them how?
Re: Sky hub
@Botchway
Switching off the Hub at the mains for at least an hour should trigger the allocation of a different public IP address when it repowers, although it appears that these have been getting 'stickier' recently.
