Discussion topic: Sky hub wifi box overheating
This message was authored by: Liamjo
My sky wifi box is overheating, what do i do
Re: Sky hub wifi box overheating
@Liamjo the older flat style Sky hubs get quite warm normally so unless they are so hot you cannot leave your hand on them there is not likely to be a  fault. Otherwise make sure the hub is not got other things on it and is not on a surface that stops it cooling if it is still worrying you give Sky a call,
