Discussion topic: Sky hub flashing green light, phone connected without internet
Message posted on 13 Aug 2024 03:49 PM
Sky hub(White) is slow flashing a green light. Wifi on android mobile is connected without internet and pc has no connection with a wired connection.
Message posted on 13 Aug 2024 06:08 PM
Re: Sky hub flashing green light, phone connected without internet
@Leeroy1977 If you follow the link below and click on the white router it will take you through what directions you have to take to fix your issue.
Message posted on 13 Aug 2024 07:23 PM
Thanks for the reply, i have contacted sky and they ran some tests. Unplugged both router and ont box for 15 minutes to reset system.
After which router was still flashing slowly green as before.
So sky are now sending a new router to see if it is a faulty router. Fingers crossed.
I have another router plugged in now but connection is hit and miss i.e it has connection but very slow and struggles to load a page.
