Discussion topic: Sky high fibre broadband 5ghz
Message posted on 07 Dec 2024 04:09 PM
HI All
I have a number of smart plugs that work on 5GHZ. I didnt want to change my router to 2.4 so disposed of my old smart plugs and invested in 5ghz. They all work perfectly. I have just received notification of an upgrde to full fibre broadband but before I accept can someone tell me if they know whether it is 2.4 or 5ghz?
Any advice and / or information gratefully accepted.
Regards
Message posted on 07 Dec 2024 04:13 PM - last edited: 07 Dec 2024 04:14 PM
Re: Sky high fibre broadband 5ghz
Broadband isn't either of those, because it's cabled.
WiFi broadcast from a Sky Broadband Hub or Max Hub (the models compatible with FTTP) is on both 2.4Ghz and 5Ghz bands by default.
