9
This discussion topic has been answered Discussion topic: Sky gigafast
This message was authored by: Nannan+Pandrea
Sky gigafast
I just recently had the sky gigafast installed as it has no WPS button IV been unable to connect it to my sky q box, I have had to connect it as if it's a different provider as that way I could put the password in instead of the WPS button, but because I have connected it that way it doesn't see my sky mini boxes and neither can I use sky max to control my devices, I have also tried to connect with ethernet cable but still have the same issue, I have been through all the various steps that sky provide and cannot make it connect as a sky hub
Re: Sky gigafast
@Nannan+Pandrea you do have to conne ct your main Q box to the hub using the password method. However your Q mini boxes need to be connected to the main Q box using WPS not to the hub.
Re: Sky gigafast
Re: Sky gigafast
@Nannan+Pandrea Connecting older devices see the link.
sky connecting devices
https://www.sky.com/help/articles/connect-devices-to-broadband-start
This message was authored by: peter-marlow+1966
Re: Sky gigafast
What router do you have  all routers have was button, i  have sky wifi max hub  and the was button is on the side
P c marlow
Re: Sky gigafast
I  also have gigafast  broadband 900mps
P c marlow
Avatar for Nannan+Pandrea
Re: Sky gigafast
I have the sky gigafast ( and it doesn't have a WPS button at all
Re: Sky gigafast
@Nannan+Pandrea You have to use the secure password entry to the connecting devices!
Re: Sky gigafast
What colour  is your  hub,router? Black  or white
P c marlow
Re: Sky gigafast
It's white and cylinder shaped
Re: Sky gigafast
@Nannan+Pandrea Use the link select your hub, say white light and then the box for connecting sky Q.
