Discussion topic: Sky gigafast being installed in two weeks
This message was authored by Sean2022 This message was authored by: Sean2022
Hi im moving from virgin 1 gig to sky gigafast. Wjats the best bang for buck wifif 6 router i can buy to replace the sky router and do any of these alternative routers come plug and play ?
Thanks in advance
Sean
Re: Sky gigafast being installed in two weeks
@Sean2022
Asus rt ax56u
Asus rt ax58u
Asus rt ax68u
Asus rt ax86u
Asus rt ax 88u
Asus zenwifi xt8
All work etherneted to the sky hub if you wish to retain internet calls or directly etherneted to the ont if you don't mind losing your internet calls
Sean2022
Thanks bud are these plug and play
@Sean2022
The above assumes you are in the uk
P.S. for the above you would need initially firmware update the asus sequentially until it doesn't update anymore whilst etherneted to the sky hub
Then remove sky hub and ethernet the asus to the ont and locate client identifier (option 61) and type in :-
anything@skydsl|anything
That should be sufficient to authenticate with sky servers
Sean2022
Cheers for your help bud what one would you personally recommemd ?
Sean
@Sean2022
Personally i would recommend asus rt ax58u or above to get the best of the increase range and speed of the wifi 5 ac channels and the wifi 6 ax channels
The rt ax58u is around £150 whilst the others range up to > £200-£250
Sean2022
Cheers bud i went full steam ahead and bought Asus rt ax 88u on amazon for £309
@Sean2022
Good choice . 👍 Get back to us when it arrives and a few of us can talk you thru setup although it is pretty much (almost) plug and play .
Also don't forget to download the asus router app for android or ios as it makes it easier to control advanced features
Sean2022
Cheers will do
