7
This discussion topic has been answered Discussion topic: Sky full broadband and sky booster
This message was authored by: Leisurely
We recently had full sky fibre installed and a sky puck. We've installed a sky broadband booster skyse210, in another part of the house, the booster is showing three green lights using wps but it's asking  for a password. It won't accept the broadband hub password?
This message was authored by: cookiemonsteruk Answer
Re: Sky full broadband and sky booster
@Leisurely
As far as i am aware the se210 can only be used to connect a sky q mini to the sky q main box via it 5ghz wifi channel when using the max hub . In order to use the sky max hub sr213 you need a sky max pod if you want to connect the skx puck/stream box
@Leisurely
What sky router did you receive?
Avatar for Leisurely
SKYHG12T white in colour installed by Sky engineer early August connected to full fibre.
@Leisurely
Thanks for the reply, I'll call Sky to obtain a pod
much appreciated
@Leisurely
Did you take out the wifi max subscription in which case its free. But the sky max router is now sent out with all new fttp subs so you would then have to subscribe to wifi max at £7.50 pm if not already subscribed
Hi, we took up Sky's current offer that didn't include the subscription you mentioned but we're getting very weak signal in one area of the home so will relay this to Sky next week
thanks
@Leisurely
Just make sure when you take out the subscription you ask for the pod to be sent out right away
