Discussion topic: Sky fibre
This message was authored by: Delmitch
Sky fibre
Just got sky fibre and my phones keep dropping the WiFi connection even when sitting right next to router spend more time on phone data than WiFi any fixes?
Re: Sky fibre
@Delmitch check that your phones do not haveca setting like WiFi Assist on as that will cause the phone to switch to mobile data if that is faster with 5G that can happen even with a fast fibre connection . On iPhones the setting is hidden atvthe bottom of the Mobile Data Settings.
Oddly you can getwifi drop outs if you are too close to a WiFi router being a metre of so away should avoid that issue.
Avatar for Delmitch
Re: Sky fibre
Hi
thanks for the reply, no no WiFi assist on phone this only happened when i switched to fibre. Also seems signal strength ain't  as strong as all devices drop in the back bedroom an issue that never happened before.
reset WIFI and everything no improvement.
