Discussion topic: Sky fibre max hub 6
This message was authored by: Carl108
Sky fibre max hub 6
Ive just had the fibre and the hub connected but when I input the password it says incorrect password
Re: Sky fibre max hub 6
@Carl108 Make sure the password is exactly as you see it, upercase/lowercase and any numbers, sometimes a letter O looks like a number 0 zero and you are matching to the sky ssid at the same time for the selection as detailed on the card or the label bottom off that sky Hub!
