Discussion topic: Sky fibre broadband
This message was authored by: IRIS7
Sky fibre broadband
I recently had sky fibre broadband fitted. Since then I have not been able to connect to my sky services
Re: Sky fibre broadband
@IRIS7 Fibre upgrade should have nothing to do with you getting to your sky services!
Avatar for IRIS7
Hi. Thank you for your reply. But ever since I have had my new router it keeps saying I cannot connect to sky services,  Such as sky cinema. I have followed the instructions asking me to press and hold the WPS button but after that it keeps telling me that it can't connect.
@IRIS7 What sky hub do you have fitted the Black one or the White one, link if you are not sure will show you the pictures!
Avatar for IRIS7
It is the white one.
@IRIS7 Are you using the old Sky Q box or in streaming, the WPS connection more than likely will not work hub wise!
See the link below but look at connecting older devices!
sky connecting devices
https://www.sky.com/help/articles/connect-devices-to-broadband-start
