Discussion topic: Sky dropping broadband , signal
This message was authored by: Alex9387
Message posted on 03 Nov 2025 07:51 AM
The generic issue of sky q , loosing broadband signal ! Is absolutely shocking, all the smart Tavs i. The house don't have problems with the BT broadband to watch , Netflix, Prime or paramount. But sky itself can seem to hold the connection. Bt hub can not now separate 2-5 ghz channels which sky Q seems to connect on even stopping the 5ghz channel still doesn't work . Seems like sky only won't you to have sky broadband as my Q box is more than happy to connect to the neighbours sky broadband box and can't find my router which is next to it .. this is one reason I might be dropping sky
