21 Jun 2023 09:19 AM
In the Republic of Ireland it would appear vlanid= 10 is required for fttp . Its 101 in the uk for fttc and disabled for fttp 👍
21 Jun 2023 09:24 AM
Posted by a Superuser, not a Sky employee. Find out more@cookiemonsteruk I had seen both about and was not too sure if it was one or the other.
21 Jun 2023 04:15 PM
When you folks say that the username/pw for PPPoE in RoI is "anything @skydsl.com and anything am I correct in that it's anything in that I could put crocodile @skydsl.com and alligator and it would work?
Or does it have to be specifically anything and anything? Was always a bit confused when reading that.
21 Jun 2023 04:20 PM
The interpretation is correct, anything you like in those fields marked 'anything'.
27 Jun 2023 04:53 PM
Hi chaps,
@mae-3 @cookiemonsteruk so I just recently got my Asus AX6600 XT8 and tried to get it working with my sky fibre.
During setup I chose pppoe and put in my 'anything@skydsl|anything' and where it asked for special ISP requirements I put in 10 for vlan.
Now I was doing all of this through the ASUS app and it set up the network and all that but it's not connecting to the internet. I turned everything off for 30 minutes included the ONT.
any ideas?
27 Jun 2023 06:56 PM
The PPPoE details are user 'anything@skydsl' and password 'anything', eg: the pipe '|' symbol isn't required.
