Discussion topic: Sky call line hanging up on me
Message posted on 02 Jun 2024 11:58 AM
The sky "contact us" line is not working. I call up and the automated voice suggests topics but hangs up on me after 17seconds.
I am trying to call because my broadband constistently registers as being under my speed gurantee everywhere but on the sky website. Fast.com shows it being constantly under what I pay for, and the sky website says it's "working".
I am tired of trying to fix this and having to constantly call to have some technican bump my speeds
Message posted on 02 Jun 2024 12:00 PM
Re: Sky call line hanging up on me
Could you post your hub statistics
Message posted on 02 Jun 2024 12:09 PM
These are the statistics
I am looking for a sky contact number for sky that doesn't immediately hang up on me.
Message posted on 02 Jun 2024 12:11 PM
The stats look fine. What device are you using to measure the speed ?, are you using wifi? Best to use an ethernet connection when using fast.com
Message posted on 02 Jun 2024 12:13 PM
@FreddieCooper wrote:I am looking for a sky contact number for sky that doesn't immediately hang up on me.
All call to Sky go to the same bank of agents wherever they may be based.
You can call Sky free by dialling 150 from a Sky Talk landline or a Sky Mobile, otherwise you can use:
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ and it provides a 0333 number.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ and it provides a 0818 number.
(The forum doesn’t allow us to type the numbers in full).
You will find that similar to calling other large companies the start will be automated which may also try to send you here to the forum. Stay on the line as long as possible and don’t hang up. If necessary say nothing when the automated system asks you what your call is about as it should then route your call into a queue for the next available agent.
Message posted on 02 Jun 2024 12:16 PM
This does not work as 16-18 seconds into the call they hang up on me.
Message posted on 02 Jun 2024 12:17 PM
I don't have a means to ethernet direct, so yes I am using wifi.
The issue is that about once a week my connection drops to half the speed it's supposed to be, and then I have to run checks and reset the box (which I just did 20mins ago) - it's very frustrating - I am supposed to have 500mb/s and most of the time I only get 100mb/s until I reset the box or complain direct to sky - if I complain then the connection takes a month to drop to lower speeds.
I am trying to contact sky to talk direct to an advisor
Message posted on 02 Jun 2024 12:22 PM
Hundreds of customers manage it daily. They is no other means of calling. As stated above stay on the line as long as possible & don’t hang up. If necessary say nothing when the automated system asks you what your call is about as it should then route your call into a queue for an agent.
